Activities
- Overview
- UI Automation
- UI-ANA-016 - Pull Open Browser URL
- UI-ANA-017 - ContinueOnError True
- UI-ANA-018 - List OCR/Image Activities
- UI-DBP-006 - Container Usage
- UI-DBP-013 - Excel Automation Misuse
- UI-DBP-030 - Forbidden Variables Usage In Selectors
- UI-PRR-001 - Simulate Click
- UI-PRR-002 - Simulate Type
- UI-PRR-003 - Open Application Misuse
- UI-PRR-004 - Hardcoded Delays
- UI-REL-001 - Large Idx in Selectors
- UI-SEC-004 - Selector Email Data
- UI-SEC-010 - App/Url Restrictions
- UI-USG-011 - Non Allowed Attributes
- SY-USG-013 - Private File Invoke
- SY-USG-014 - Incorrect Execution Template Placeholders
- Applications and technologies automated with UI Automation
- UiPath Browser Migration Tool
- Computer Vision Recorder
- Click
- Hover
- Type Secure Text
- Send Hotkey
- Type Into
- Check
- Select Item
- Select Multiple Items
- Get Text
- Set Text
- Activate
- Highlight
- Set Focus
- Anchor Base
- Context Aware Anchor
- Find Relative Element
- Indicate On Screen
- Element Exists
- Find Element
- Wait Element Vanish
- Find Children
- Get Ancestor
- Element Scope
- Get Attribute
- Set Clipping Region
- Get Position
- Take Screenshot
- Wait Attribute
- On Element Appear
- On Element Vanish
- Click Text
- Hover Text
- Find Text Position
- Get Full Text
- Get Visible Text
- Extract Structured Data
- Text Exists
- Click OCR Text
- Hover OCR Text
- Get OCR Text
- Find OCR Text Position
- Microsoft OCR
- Microsoft Azure Computer Vision OCR
- Tesseract OCR
- Google Cloud Vision OCR
- OCR Text Exists
- Click Image
- Hover Image
- Find Image Matches
- Image Exists
- Find Image
- Wait Image Vanish
- On Image Appear
- On Image Vanish
- Load Image
- Save Image
- Attach Browser
- Close Tab
- Go Back
- Go Forward
- Go Home
- Inject JS Script
- Navigate To
- Open Browser
- Refresh Browser
- Set Web Attribute
- Attach Window
- Close Window
- Get Active Window
- Hide Window
- Maximize Window
- Minimize Window
- Move Window
- Restore Window
- Show Window
- Export UI Tree
- Invoke ActiveX Method
- Inject .NET Code
- Click Trigger
- Key Press Trigger
- Click Image Trigger
- System Trigger
- Hotkey Trigger
- Mouse Trigger
- Get Event Info
- Monitor Events
- Get Source Element
- Replay User Event
- Block User Input
- Use Foreground
- Callout
- Copy Selected Text
- Get From Clipboard
- Set To Clipboard
- Close Application
- Open Application
- Start Process
- Get Password
- Tooltip
- Click Picture on Screen
- Click Toolbar Button
- Read Statusbar
- Select Dates in Calendar
- Select Menu Item
- Expand Tree
- Call Transaction
- SAP Logon
- SAP Login
- Table Cell Scope
- SAP Session Attributes Change Trigger
- Expand ALV Tree
- Expand ALV Hierarchical Table
- Use Application/Browser
- Check App State
- Check/Uncheck
- Click
- Extract Table Data
- Get Text
- Get URL
- Go to URL
- Highlight
- Hover
- Keyboard Shortcuts
- Navigate Browser
- Select Item
- Take Screenshot
- Type Into
- Get Attribute
- Get Browser Data
- Set Browser Data
- Mouse Scroll
- Inject Js Script
- Drag and Drop
- For Each UI Element
- Application Event Trigger
- Click Event Trigger
- Keypress Event Trigger
- Set Text
- Check Element
- Fill Form
- Perform browser search and retrieve results using UI Automation APIs
- Web Browsing
- Find Images
- Click Images
- Trigger and Monitor Events
- Create and Override Files
- HTML Pages: Extract and Manipulate Information
- Window Manipulation
- Automated List Selection
- Find and Manipulate Window Elements
- Manage Text Automation
- Load and Process Images
- Manage Mouse Activated Actions
- Automate Application Runtime
- Automated Run of a Local Application
- Browser Navigation
- Web Automation
- Trigger Scope Example
- Mobile Automation
- Release notes
- Project compatibility
- Get Log Types
- Get Logs
- Get Page Source
- Get Device Orientation
- Get Session Identifier
- Install App
- Manage Current App
- Manage Other App
- Open DeepLink
- Open URL
- Mobile Device Connection
- Positional Swipe
- Press Hardware Button
- Set Device Orientation
- Take Screenshot
- Take Screenshot Part
- Element Exists
- Execute Command
- Get Attribute
- Get Selected Item
- Get Text
- Set Selected Item
- Set Text
- Swipe
- Tap
- Type Text
- Draw Pattern
- Terminal
UI Automation Activities
Last updated Apr 26, 2024
Here you can check the availability of the package and its activities with the different project compatibilities in UiPath Studio.
Activity Package |
Windows - Legacy |
Windows |
Cross-platform |
UiPath.MobileAutomation.Activities |
